I like to use it in bed, but the flashing nature of volume/level led keeps my wife awake!!! Any way to turn it off???
tape
duct tape
Thanks for the suggestion, but I donโt wanna stick duct tape on the unit. I was hoping for a systems setting / hidden functionality.
I guess when on headphones you can internally level everything down (the led cross will stay low) therefore producing not that much light and turn up the master volume knob until youโre good.
I would consider the tape solution with a non sticky material.
i use a paint pen to cover annoying leds. comes off instantly with isopropyl
a less aggresive solution is the sticky part of a post it note. the weakest tape i can think of but works well.
I use these all my excessively bright LEDโs - you can still see the LED, just dimmer. Comes off easily if need be and doesnโt leave any marksโฆ
blue tape or painters tape would work well also
and not leave any residue behind
