It’d be very handy to easily play the four tape tracks simultaneously when looking through the growing archives of tapes on the hard drive. Any recommendations?
garageband
In theory, the AIFF spec allows for multiple channels to be combined in one aif. The resource below suggests any number of channels could be supported, not just two.
ableton
maybe a nice way around this is, if the OP1 exposes its mixer parameters anywhere, to have a dedicated backup app/workflow that merges the 4 tracks into a tape preview file, ideally applying the output eq/mixer/drive parameters…
AUDACITY would be simple drag and drop 4 files for 4 channel playback.
thanks for the input! what i’m looking for however is to just select the tracks with shift then press space (and some key) in Finder and have them play
thanks for the input! what i'm looking for however is to just select the tracks with shift then press space (and some key) in Finder and have them play :)
nothing as easy as that sorry.
ive come to appreciate the four separate tracks out of my op1. my sample fodder folder has grown immensely since purchasing the op1. and getting them all linked together is as easy as dragging them into seperate tracks in my DAW.
this
I’m not sure if this is an acceptable answer but can’t you just record the 4 tracks to album on the op-1 itself and then export that? Then you can run thru the files and play them with the shift key on your mac.
@jonnyjonnyc i guess that’s a reasonable solution. i think i’ve so far for logic logistics sakes only emptied the op-1 once the album+tapes are full, and that means i’m super eager to empty it to be able to use the tapes once again haha. i guess i should do this actually!
