Arming the track to start recording when you hit a note/key no longer works. I am able to shift+rec to activate the armed recording, but when you start playing notes/keys the recording doesn’t trigger. Anyone ever have this problem?
Same here
Yep happened to me too. I think I got it working again but need to go back and double check. Really unhelpfully I can’t remember what I did to sort it.
factory reset maybe?
thats so weird…unless it broke with a new firmware?
I did the factory reset and still no luck
Ditto here on armed not working thought I was loosing it
i’m on 235 and it still works for me
i just hold rec and then hit some notes and it starts recording right away
this is how i’ve always done it atleast.
i noticed @HumorRelevant u mention using shift+rec
this is not the same thing
shift+rec arms record but u control the tape speed manually
peep the guide
https://teenage.engineering/guides/op-1/tape-mode#8.11
"a quite special recording technique is to put the tape in rec arm mode and control the speed manually. to do this press shift + rec. you are now recording but the reels are still. "
Savior! I remember now why someone made a 3D printable key holder for times you need both hands free
i mean once the recording is initiated u dont need to keep holding it down
I see… thanks!
Yeah totally! I just mean for handheld type situations it’s not so easy
