When using “each” in the arp I’m intermittently getting this high ptiched trills. Can someone explain what is going on?
Weird! I have no idea!
Did a factory reset and the high pitch noise seems to have dissapeared - will se if it returns. But still seems to be a weird silence on the first note when triggering the arp. Is this standard / expected behaviour?
Side note: is the visualization just of the actual note value (irrespective of octave)?
My field doesn’t have that delay, but it’s putting visualizations of a note there when you hit it, it’s prob due to the patch you have. Try different patches.
Also, the visualization is just of the note on a scale, no mention of octave. Try holding down a single key and you will hear diff octaves with the same note displayed.
It’s a sample patch - and even with completely standard ADSR and effects / lof turned off - the issue is there.When turning the ARP off I can play as many notes as I like without any issues. Also issue remains with other patches.
Another patch with no crazy settings and weird behavioru -
Is this a feature or bog of the EACH setting in the arp
Is there anyone who can test with there arp at same settings if they get the “extra” (silent) note which is a different pitch than the rest?
Confirmed issue now from TE support
Excellent find, thanks for submitting the bug to them!
