I really like the kind of mixers that enable to record all tracks separately.
I have a cheap Multimix 12 FW, it’s good enough for me… And thus I have no need of a soundcard as it acts as one.
I guess the technology now is impressively better but this little mixer has worked without any pb for +10 years, I’ll look for a new one when it’s dead or most probably when FireWire is no more
Anyway, I would recommend to investigate deeper, it’s really confortable to be able to record any or all your gear at once…
@eesn I have read bad reviews about the RME Fireface UCX on AudioFanzine… Like the sound is pretty good, but the build quality not that much.
@eesn I have read bad reviews about the RME Fireface UCX on AudioFanzine... Like the sound is pretty good, but the build quality not that much.
I own one. The UCX is built like a tank. Same for the drivers&software. My only gripe with it is that it heats up when in constricted space and the weather is warm; even then it works flawlessly. Zero issues since I bought it. No idea why anyone would complain about build quality on this thing.
I have the blackjack as well. very well built, sounds good. Has a pretty nice headphone amp in it actually, and the mic pres are good (haven’t used them much, so I don’t have much to judge them on)
don’t use it too much anymore (prefer recording to my zoom h4n, which can also function as an interface anyway), but it was good when I used it.
Saffire pro 24 FireWire has been my workhorse interface for the past 4 years… Low latency, good drivers, 4 in 6 out, can add another 8 I/o via adat. No complaints other than the software being a not confusing.
I’m looking for a audiointerface too. I start with thinking about getting the new scarlett … head over to motu & rme … but does i really need this kind of expensive superhighquality as an non-pro? no. so i’m back where i startet with resarching … the scarlett 18i8 2nd gen. people say sounds the same like the saffire … my only concern: does the low latency driver is reliable? or does focusrite just wanne be the kings of low latency on USB?!?
Once you get your head around it, the iPad configuration app for iConnect Audio4+ is great. No complaints about the sound quality either. Plug a USB hub to the host ports, and you get loads of USB MIDI too. I’ve been very satisfied with it.
Once I hit a weird bug, where latency was getting bigger bit by bit, but that’s just been once.
