By holding Track and dial the blue Encoder on an Audio Track you can active Sample Retrig. But it seems that the different Samples are retrigged in different speeds.
Is it possible to change the retrig speed?
I think you’re referring to loop play mode. The speed of that loop it dependent on the sample’s start and end position which can be adjusted in the envelope (Green LED) page of the track.
Nope not exactly but thx for help:)
I meant a repeat function in different speeds but i found out that i can achive this with the multiply-step-component!
This Video helped (about 03:00 Minute Mark):
