Best way to get a mono output on OP1?
Hey you guys,
I want to run my op1 output in mono- what’s the best way to do this?
Why would you do that ?
Anyway, the best thing it to get (or build) a Y-cable.
It’s always useful when you need to plug your OP-1 to a mixer…
You could just crank all the mixes to hard left or hard right…
But not a mix…
Stereo jack to two mono Y cable is a great thing to use with the OP-1.
You can send some channels to Left, Some to Right and Effects with the Mixer Sends to them individually.
Thanks! Yeah, the y cable/pan combo makes the most sense. But…will that make the master effects sound weird?
Sorry to butt in, but just a clarifying question: if you go from a TRS stereo jack into the OP-1 to a TS mono jack into a mono mixer input, will all of the sonic content from the OP-1 go into the mixer?
From what I understand you may lose a channel, as some of the TRS -> TS cables either lift one pin, or tie it to ground. You can use a crude summing mixer to do this Stereo -> Mono Summing.
This is what the Korg Monotron Delay does by using 2x resistors of the same value to sum up the signals (passively mixing 2 channels together -> in this case L & R from the TRS).
I’ve attached a link to show this:
https://brashleraudio.files.wordpress.com/2012/08/screenhunter_02-aug-27-19-35.gif
Definitely easiest to just hard pan the signals to L/R respectively, and use separate Mono channels on your mixer for input.
Thanks, @picoVolt. Perfectly explained and illustrated.
No problem @SFKeydel. Just a quick google with the right terminology, and you can get all kinds of reliable info/examples from the Internet :smiley:
