changing the master effects while playing live without hearing yourself go through all the effects
hi, is there anyway to change the master effects on the op1 while keeping the effects off because when recording to the record i can hear myself going through the different effects when i playback? also is there any way to preset the master effects so that if you do change to them they will not auto reset?
thanks,
t.
I don’t believe so. I could be wrong. Might seem a hassle but get comfortable with bouncing and resampling. Use the tape, it’s the op’s strongest feature. Coming from a DAW i hated it at first cause i always kept my tracks in MIDI to the last minute. But i never finished stuff till the end either :slight_smile:
