Hi,
Press all track keys at once and let go of the one that you want to select last. Takes some timing to get used to but it works
That still requires very quick timing, and would most likely still result in cutting some track out momentarily.
@beefinator yes It is not perfect… but if you are it is sweet. I find i hit and the wrong beat and funky shit happens. but timing is key in live performance… if a dj is of a millisecond the beat are offset.
So if you want perfection you have to be prefect or you need to use a DAW an fix slop after. As I can be lazy the later is best for production value. But in the battles I strive for more. and all sets I do in battle are first or second takes of a live performance.
Cool, will just work on my timing, thanks!
