Cinematic Pads | Sound Pack for the OPXY
Hi all, I just released the Cinematic Pads Sound Pack.
A unique sound pack for the Teenage Engineering OPXY featuring cinematic, evolving, lush and characterful pad sounds available via my payhip or gumroad page
Cinematic Pads contains 50 multi sampled instruments and as with all of my sound packs all the source wave files are heavily optimized. This enables you to use all 8 multi sample engines of the OPXY with these patches simultaneously without the XY running out of memory resulting in patches not loading.
All Patches are crafted with great care using customised (multi) samples so these are not just simple presets, but custom sounds which you can use for your ambient, cinematic, drone or all other kinds of electronic music.
In below video you can listen to a simple patch play through of the Cinematic Pads sound pack:
The Cinematic Pads Sound Pack is Inspired (but not the same) by my previous ‘OP-1 Field Path’ sound pack which I now also made compatible with the OPXY. So If you previously purchased the Field Path Sound Pack for the OP-1 Field or the complete OP-1 Field Bundle you can re-download the ‘OP-1 Field Path’ Sound Pack for free using your previous receipt and download link and also use the patches of the Field Path Sound Pack on your OPXY!
Thanks for the support and enjoy the sounds!
