Colors In Space Sound Packs and Tutorials
Sound in Motion is a custom sound pack for the Teenage Engineering OP‑XY, designed to expand its sonic palette with evolving, ambient textures. It’s my newest and favorite pack so far, featuring 50 projects, each built from four layered presets. Every project was carefully crafted to feel unique, with an emphasis on movement and atmosphere.
All multisamples were created in Logic Pro using Autosampler with the Penrose setting. To keep file sizes manageable, I trimmed long tails after looping. Each preset uses high cutoff to remove low end, so the overall sound stays clear and never muffled.
Some projects are built entirely from multisamples, while others combine them with the OP‑XY’s synth engines. In many presets I used LFOs and the arpeggiator to create a faux granular effect. Polyphony is pre‑assigned in the config menu, so you won’t need to adjust it manually — this keeps the OP‑XY running smoothly without overload.
On the master chain, I boosted compression and volume, and added creative distortion to give the projects extra punch and character.
This pack is alive, dynamic, and ready to inspire new ideas straight out of the box.
Thanks for listening and for all the support — it means a lot.
Installation Instructions
Presets
• Inside the download, you’ll find two preset folders: clouds and p (yes, that’s the name).
• Simply drop both folders into your OP‑XY presets folder.
Projects
• Open the project folder in the download.
• Copy all 50 project files.
• Paste them into your OP‑XY project user folder.
That’s it — once copied, the presets and projects will be ready to use.
Hey ya”ll
To celebrate April 4 (SP‑404 Day), I’m giving away a special project for the Roland SP‑404MKII. This pack includes 50 ambient samples/presets, crafted to bring spacious, atmospheric tones straight to your sampler.
Load it up and you’ll have instant access to pads, textures, and evolving sounds designed for ambient production and experimental workflows.
Free to download today — enjoy the vibe and happy SP‑404 Day!
Hello everyone,
I just released a new soundpack for the OP-XY.
Hey Ya’ll,
Here are a couple new free soundpacks I just released for the OP-XY.
As always awesome :fire:
Cheers bro!
Mate, they are awesome sounding!
Thanks for sharing :folded_hands:
It’s been too hot to step outside in Vietnam this week, so I stayed inside and made a bunch of music.
The workflow was straightforward: I put together some heavy beats, chopped them up, threw them into the OP-XY, and then chopped them all over again.
If you use the OP-XY, there are 55 native presets pre-formatted and ready to load. If you use any other sampler or DAW, the exact same loops and cuts are included as standard WAV files.
The Folders:
 “Heat”: The 55 OP-XY presets.
 “Beats In Heat”: The universal ⁠.wav⁠ files.
What you get:
 33 Drum & Bass / Jungle files: Fast, rolled-out breaks and heavy rhythm tracks.
 22 Experimental Lo-Fi files: Dusty, abstract grooves and hazy textures.
It’s 100% free. Just put ⁠0⁠ in the price box and download it.
Hey Ya’ll. Here is a free one for ya.
Hey Ya’ll! This is gonna be a goodie..
Hey Ya’ll
Bristol has finally been released.
