Hi,
Small workflow question: is it possible to move single/groups of patterns from one project to another? I know it is possible to move an entire project into a different slot, but how about single patterns from one project into another? Perhaps I am overlooking something really simple here…I have a bad habit or poorly organizing ideas on the unit…
I think you can do this, but it may be copy a track of a pattern, not the whole pattern. See my thread about 12 hours on a plane with the opz, I might mention it there. Also, it’s in the manual, but I can’t remember the combo off the top of my dome.
What you do is: press and hold Project and press Shift to copy the currently active pattern. Then keep holding Project and select the destination project and pattern slot and keep holding until your pattern is copied (leds flash red). This copies the whole pattern. You can also keep holding Project and select multiple patterns to copy more than one pattern.
It’s in the manual here (though it doesn’t mention copying to a different project which, of course, you can do): https://teenage.engineering/guides/op-z/project#copy-pattern
