So for a while Ive been using a version of the modded OP-1 firmware using the tool available on GitHub but recently had to reformat to troubleshoot some audio dropouts. Now for some reason when I go through the same process to load the firmware I get an error from the op-1 “error: missing ustar tag” or and allocation error “firmware not found”. I think it has something to do with the way Python (3.8) compresses the file but changing that is outside my limited realm of knowledge.
Anyone willing to upload a working version for me? I was using a firmware with ALL mods enabled (iter presets-iter filter subtle-fx gfx-iter-lab gfx-tape-invert gfx-cwo-moose) and I find it really hard to go back to using that tape at the bottom of the screen (my neck hurts!)
@JohnnyEgo Well, are you able to compile a version? I’ll gladly try it out for you but so far I have not been able to make a working version with Mac (10.14.6) and Python (3.8). “Missing ustar tag” every time.
FYI, this is not unusual while using python. Programmers often use a tool like PyEnv to keep their different projects compiling with a version of python that is working until they are able to update the project to work with newer versions if they are still maintaining/working on the project.
If you don’t need to have more than one python version, I would suggest not updating until you know that the firmware tool has been updated/tested with it. If you do need to have differnet versions of python on one system, you should learn to use PyEnv or another virtual environment tool (there are others, PyEnv is the one I used in the past).
Hi!
I’m trying to get the repacker working but I seem to be in over my head… op1repacker seemed to install fine but gives me a syntax error at “unpack” when I try to run it… anyone have the patience to help me out here? I’d be ever so grateful.
