Does your OP-1 currently have Hundekraft 3 installed?
just installed. very cool! shift + 4 for me just mutes the tape like stock. not getting qrec enabled.
Qrec only works when you have a loop active, the key combo is shift+regular 4 not T-4. Those are my best guesses of what happened. And thanks for trying it out! Let me know if you run into any other issues and Iāll be happy to help.
ahh thanks! just 4, not T4, did the trick. groovy. a one bar count in like we finally got from other cfws would be nice. Iām loving stereo! and the waveform view is great. seeing the bars visually is nice.
idk if your on the discord but this firmware definitely deserves itās own channel. i gotta keep reading the manual. the master fx section is problematic? every time I try to go to it it flashes FX off. also, lfo 2 and 3, can it only affect the fx and the channel strip? i donāt see the instrument and envelope/pan settings.
also, long term vision? think youāll support one the other plug in formats?
Did you press T-3 to activate the strip on the master? You toggle it like the drum and synth strips.
Yeah, the extra LFOās are limited for now. I need to build a better destination browser before adding more, itās already a bit messy.
Synth has a second T-2 screen for settings, toggle it with a second T-2 press. Only pan for now. Drums have no support for pan at the moment. Iām building a ASR-10 inspired (sound character wise) sampler that has pan per key but itās a lot more work to be done there.
No plans to add plugins/app store style features for now. Way to much to work on to get the core ideas fleshed out and stable. Working on porting everything to Field now too.
I have a pre-draft for adding custom content to SilverTape but itās far in the future.
That Roland synth sounds great though!
Sounds great! But this whole gatekeeping behind Opus is getting old quick, iām sure someone will port it to a more community based firmware sooner than I can.
for real. itās crazy to say youāre gatekeeping free software.
side note: i couldnāt get hundekraft to update (99% bad cable issue) so then I formatted and flashed SilverTape. thatās all to say that switching is easy. Iām gonna try Opus soon. also if SilverTape crashes it wonāt turn off if the usb cable is plugged in. and it crashes regularly using usb audio out.
Forgive me, I interpreted it as an exclusive to Opus!
You had me hooked at BOC lol!
Wow, the Vapora synth is another level. I think it gives the widest range of sounds out of all the OP-1 synths. Whoever made it is a genius.
Do a full firmware update the regular way (COM-power on etc), then it will work fine from the web updater.
Nice to hear! Performance was a big focus in this one, and big thanks to @JohnnyEgo for testing and helping find some of the weirder bugs.
Thanks for the feedback. Iāve tried to make the different paths (USB/full fw) clear, but Iāll see what I can improve.
Once you are on 3.x, you should not need 246 file anymore, it just updates everything from the browser via USB. The file path is for new users/coming from other CFWs.
It did ask me for the 264 file even though it detected HK 3.0.3 on the device. Thatās why I was confused. Also, the first time I provided the file it did not do anything after that. Then I started from scratch, it asked for the 264 again but this time it followed through with the update process.
Would love to get some additional information in which scenarios it crashes. I havenāt managed to crash it with USB-audio yet.
the stability of Hundekraft is unmatched and that does also goes to the stock synthesizers, everything has a bit more room to breath and thatās pretty fantastic, still a revolutionary momentum weāve created by staying strictly open source (that helps the most to not brick things) and accelerating the initial momentum still into unbelievable heights. the original passion of just doing it lead to Hundekraft as we all know, community driven workshop for the OP1. letās make more music with it, itās the OP1. ![]()
Thanks for the details, that makes it clear on how to improve the user experience. I wrote wrong earlier, 3.1 + 3.1.1 was a core update. That means it needs the original 246 to patch. It still updates via USB (takes about 10mins) or via file the regular COM way.
Hey, all of these are fixed in 3.1.2 (which was released yesterday), and old oxbow is back ![]()
yesss I saw that!
thanks you so much, it all work great!
Im having an error with sample + when loading the engine, it freeze the op-1 and I need to reboot. Is there something I have to do?
