For the Quad LFO, do you think it would be possibe to have an positive +, negative - and bipolar +/- option? Right now it feels always bipolar.
CCs went through a complete overhaul, you may want to check today’s release #52. Don’t forget to select a midi channel on com>op1 page!
it’s not a bad idea but the problem is there aren’t any free knobs in quad now ![]()
yea you’re right!
but honestly, I could go over the phase option (SHIFT+BLUE) to have access instead to + or - or +/-
Sort of like that pattern sequencer, maybe you’ll be able to run something similar to this on the OP-1?
Love it! kind of want the whole silvertape fw to be just ascii based, but I guess the number of users might drop to, just me ![]()
Hey guys I’ve been getting this crash on OP1R, I had it in the past versions and still have it on the latest, usually happens with the sampler+. Do you have an idea what could be triggering it and how to fix it? Thankssss
I will look into it, thanks for the report.
Thanks, let me know if you need any other info!
My first ever post on this forum and just wanted to share a massive shout out to Hundekraft, Lizzard man and all the geniuses in this forum, include Mr. Claude & Codecs. DN808 your plug-in looks siiiiick!!
That would be sick and I’ll definitely enjoy it. I have an engine with ASCII graphics in development, but never thought of systemwide.
Hey thanks! Wait until you see what @LizardMan has been making. It takes OP-1 graphics to the next level.
kewl ![]()
Love the new release @popcorp, the power of open source ![]()
sorry if answered before -
on HK 3.1.4, when live-recording in the dots-sequencer, the pitch is not recorded as played.
any reason for that?
Is this in drum mode or with external midi keyboard?
Hi all! Hundekraft 3.2 is out. It’s free custom firmware for the original OP-1, built in the browser from the plugins you pick and sent over USB.
New synths
VOX is a vocoder. Sing or talk into the OP-1, hold a chord, and your words come out on those notes. Formant makes your voice bigger or smaller without changing the pitch.
SNAP is pitch correction for your voice. Keep it subtle and a shaky note just slides into tune, or crank it for the hard snap everyone knows from the radio. Hold a few keys and you get a small choir of yourself. VOX and SNAP need headphones with the built-in mic.
STRUM is a Martin HD28 acoustic, recorded note by note, that strums the chord for whatever key you press, in time with the tempo. It has 28 patterns: campfire strumming, funk, Travis picking, bossa nova, flamenco and more.
REACTOR is a power plant you play. Four rods hum in a loop that feeds itself. Turn up the heat and it howls, and if you push too far the core melts down. (credit to Fab.t for the graphics!)
MOAI, by fungiboletus, is a Minimoog-style synth with three oscillators, the ladder filter and 121 built-in presets.
New effects
RACKVERB is a late-80s studio rack: big halls, gated drums, reverse reverbs, flangers, slapback echoes and QUAD, a multi-effect with a rotating speaker. 316 programs, with an AUTH mode that keeps the grainy sound of the old units, and a CLEAN mode for a more modern sound.
ENTE, from op1r, is a sidechain compressor. Your synth ducks every time the kick hits, from a tape track, the input or a steady beat. There’s a rubber duck on screen.
New ways to play
COMPOSER writes whole songs: verse, chorus and bridge with proper chord changes, in 32 styles from deep house to film noir. Put it on the drum page as well and it plays the drums for the same song.
HOLD turns the keys you hold into a loop, for chords, lines and drones.
TRAIL plays a short phrase in your scale when you hold a note and keeps developing its idea, so the tune slowly wanders. Turn on Answer and it replies to what you play - call and response style.
Latch keeps notes ringing after you let go.
Master LFO gives you four LFOs on the master effect. (based on op1r Quad LFO)
Line clock syncs the OP-1 to a modular or a drum machine through line in. Heads-up: Eurorack clocks are often 5 to 10 V, far too hot for the line input. Use an attenuator or a line-level clock output. (Volker Junginger / ESC_CODE)
And more
MONOLIT has a new ladder filter, and its Heat makes the filter sing on its own.
Chord mode has 69 progressions now, in seven groups from pop to film and world: La Folia, Pachelbel’s canon with its walking bass, Giant Steps, Just the Two of Us and lots more. Chords can have their own bass note (G/B and so on). Shift + white jumps between groups.
The metronome can click with TICK or WOOD instead of the beep, so it doesn’t clash with the key of what’s on your tape.
SID’s sync and ring interval now steps in semitones, so it’s easy to set and always in tune.
C64ARP has eight more tables, including OCTAVE for that chip bass bounce and ALBERTI, a broken chord like a piano’s left hand.
BLOT has a truer 303 squelch. The filter follows the TB-303’s own, and the bass holds steady when you crank the resonance. (op1r)
TAPE has a second page with more play heads, a dry/wet mix and echoes locked to the tempo. (op1r)
The quad LFO gets two chaotic Lorenz waves, and there’s a new LFO type, POND, where four species compete in a pond and their ups and downs move four targets. (op1r)
Input gain for VOX, SNAP and AMP, chord strums up to half a beat slow, a new scale view, a RANDOM mode for C64ARP, better MIDI control (the master effect and mixer straight from your controller), and FX2 routing that works with every master effect.
Fixed: TOMBOLA’s balls escaping the hexagon and going quiet, STUTTER’s slices being the wrong length, sequencers playing drum pads sharp, and MIDI keyboard notes being recorded an octave off.
Getting it: https://hundekraft.github.io/op1-workshop/. On 3.1.4 it updates over USB with just your OP-1 and a cable. On anything older, you need the op1_246.op1 file once. Back up your tapes and sounds first, as always. Format if coming from another custom firmware.
Thanks to fungiboletus (MOAI), op1r (ENTE, BLOT’s 303 filter, tape page 2, the Lorenz and POND LFOs, MIDI and FX2 routing, lots of groundwork), Volker Junginger / ESC_CODE (Pulse Sync, which Line clock is based on) and Jeff Learman (the HD28 samples).
out of this world features nobody saw coming ![]()
Incredible! Bravo!
