Custom Firmware on the OP-1
My 2 cents, bridge is seriously the worst possible solution to this issue. Optimization per platform suffers from it and it introduces more points of failure each time someone modifies the other proprietary platform. If someone is actually willing and take time to port to their own platform, it’s their full right - that’s how open source works.
Why is there still a discussion as to if this is permitable? I’ll say it one more time, any closed source projects should be outright banned here as it infringes on TE, if you’re looking at it from ethical POV, as monetization option enters the picture. Correct and clear credits - I’m all in for, enforcing platform - DUCK NO!
If you’re trying to create a proprietary closed source software, come up with your own platform (by platform I mean hardware). If not - make peace with what open source stands for in the first place - someone making your thing potentially better.
I’ve been following this whole discussion, and I still don’t understand one thing: what’s the problem with creating plugins in one unified format? Why do OPUS plugins have their own special .opmod extension? What’s the reason behind it? Is it just to prevent people from sharing plugins with other users and maintain this fake sense of “exclusivity”?
We’re all here thanks to some cool people who reverse-engineered the original OP-1 firmware. I understand the desire to keep your CFW as an original, exclusive project (despite it being based on the OP-1R work), but creating a separate plugin format for it and refusing to share even the plugins themselves seems really weird to me.
all began when people were not credited enough for vibecoding, now theres drama
open source HK with plugins
and
opus closed source with creators trying to make fun of HK for not crediting them enough
in result opus people trying to close their system not releasing stuff on hk - just cause
at this moment theres drama with castle / kastle with was ported to work with HK and 808 wants it gone and lock it behind using opus.
and that’s wrong, iam sorry. 808 came up with the false narrative that “father” graphics had been “stolen” but in reality it has been a placeholder because HK did contact the author to host his own code to support it within a bigger audience.
that’s been so early within this movement that the result has been a grumpy 808 now harassing people for even trying to use Kastle, why not simply MAKE it yours by enabling the real code and base structure into the workshop. it’s interesting how he recreated that lil moment of false info (because he didn’t knew they’ve already talked about it)
it’s a dilemma and closed should be kept closed for the better :cat:
Continuing the discussion from Custom Firmware on the OP-1:
this what i did, and what i suspect others have done to some degree or other:
get an ai agent. i use clxxde. you can start with the free version but you wont get very far. get a paid version. — start with a medium or default model and choose higher models depending on the task. claude can advise you what models to use if you ask. you can use clxxde code if you want to, but you can do it just as easily through the browser and chat agent
i used the sxxxk [github] to decrypt and disassemble the stock 246 fw by pointing clxxde to it. — i used the original modifications github from early on in this thread as just a point of curiousity (op1repacker) and had clxxde examine it.
the obvious first step was to replace the filter effect with my own dsp… and then things evolved from there — ie, what about adding an effect instead of replacing, what about replacing iter, what about replacing or modifying any of the stock content, etc…
you will most likely run into the same problems and possible solutions that i think are probably common to everyone else’s firmware — theres really only a few practical ways to acheive things, but if you take your time and debug and catch pitfalls and bugs early it will save you a lot of time in the end. — my advice is start simple, then map out what you want to do
i havent pulled anyone else’s repo or even flashed or disassembled anyone else’s firmware, but i eventually will just to compare how i have done things vs how others have done it. i imagine there will be a lot of similarities just judging from what i’ve read and seen from each of the firmwares. — but my approach has probably been different to some degree — i have a certain ethos (do it te’s way where possible, do it as simply and as lightweight as possible, dont brick the unit, keep expectations in check - its not a powerful compute device, try to make navigation intuitive and as close to what the op1 already does as possible, try to keep customizations and additions (effects, instruments, etc) as modules to be loaded from disk by the firmware rather than built in to the firmware (keeping it lightweight), etc, and a bunch of other stuff)
i usually use 3 separate sessions - a planning and auditing session (ie, the brains), a researcher session to dig and research the fw, and a building session for writing and building the modifications. it seems to work well, but just a warning, clxxde and i expect other ai agents really do not like firmware work. - state plainly that it is a research hobby for a device you own and that you have no intent to distribute (or use an ai agent that doesnt care what you do).
you will also likely want a debug screen or “manager” or “utility” of some sort if your firmware evolves far enough. then you have to decide where are you going to put it, how are you going to call it, etc… i mention it because to me it is an example of “there are only so many ways to do something” that i suspect every firmware does to some degree. — various firmwares claiming that what they do is unique at the very basic levels just doesn’t hold water imo. “all roads lead to rome” as they say. — however, thats not to say that every firmware doesn’t have unique things about them. slightly off topic, but i don’t understand why one firmware borrowed anything from another firmware to begin with — but i can understand why, that once you release a firmware publicly, you have constrained it to some degree
anyways, good luck
Dude, with all due respect, you’re obviously a cool guy and you’re doing useful things, but I really don’t understand the wording “I will open my work when it’s done” when you’re ALREADY making your work open, but exclusively for OPUS users. What’s the logic behind that?
And my original question still stands: what was the purpose of creating a SEPARATE .opmod format in the first place? Because it looks like an attempt to preserve the exclusivity not only of the firmware itself, but also of everything developed for it. And then it turns out that the firmware isn’t even that exclusive, since it’s built on top of OP-1R’s work.
Exactly, seems like no one here is feeling particularly bad about taking TE’s intellectual property and running with it. I agree, the level of hypocrisy among everyone here is insane.
thanks for clarification.
i also agree why bridge while you can port it to HK your self and “I genuinely enjoy creating things and sharing them with this community.” sure.
Why are you being so self absorbed? It’s genuinely strange that you are trying so hard for this thread to revolve around you with a couple of plugins each one of us wants to use less and less the more we read.
Yes, building on TE product by that definition is theft. Get over yourself.
Can we get a mod in here?
Having said that, I gladly removed Castle from my OP-1. It’s just one of many plugins. I mean, I appreciate the work but it’s nothing special really, will not cry. Hundreds new plugins to come.
also glad that Hundekraft is now at the peak of space available for the engines, Kastle is a funny homage to this sopera here and I wish you a great time, sequencer thing looks fun, Claude having a great time building it out from your sketches, great inspiration and you may come back to Kastle once Opus is closed because of greedy behavior.
grand theft operator 1 :world_map:
Also, just to point out how narrative is spun here, the operative word is “yet”. So in a hypothetical scenario when your glorious code is finished (when your claude quota resets most likely) then the code will be free to port anywhere? Same outcome, you just want to be in power to decide? I honestly don’t understand why are you being such a diva if in the end you plan on opening the code and the outcome will be the same…unless you are not planning on that and say that just to wind everyone up.
Edit: If your plan is to have it open sourced - then it’s not theft, based on what you say. If the software is not released then don’t release it. Make up your mind dude
You are all vibethiefs! you stole the vibecode by vibeinstalling.
808 relesase it for HK, HK deletes it everyones happy no? oh you want to cage it in opus..ok.
Great point!
Hammer, meet nail!
the heat is on :melting_face: it’s so crazy if you have been absent for a few days and come back to this, i even missed the initial 3.3 release and thought something’s normal has been dropped but still this Kastle psychosis, next up Sequencer psychosis no? :woman_getting_massage:
You are just saying words dude, not actually replying to anything.
you’re so ignorant that you still think the Gem in your hand is built on your creativity or whatever, it’s all been “stolen” from TE in the first place and then it’s nothing more than “piracy + fantasy” a robot that will teach you your lil findings like you’ve been actually searching for something and found it, but it’s still not yours, maybe your fingers typing out your tokens but it needs a lot of fantasy to think you’re the one having the last word on this. why not develop for another audience? maybe this is simply not your crowd, try with the mwaves, you can even paywall it, don’t ruin the OP1 openness for the rest of the world you empty :low_battery:
Been following this here, and in the Discords - FFS, you could power an AI server farm with the amount of energy being expended over what is essentially two bald men fighting over a comb!
(Need more popcorn!)
