I would like to record a perfect loop from one of the Sequenzer…
For example:
I set up a 4bar loop.
Now i can start 100% on point by pressing shift + rec
So the tape ‚waits‘ for me to press a key…
—> the Sequenzer starts with the recording of tape.
After one cycle of my loop it instand overdubs…
For a perfect loop I have to lift the key on the last milsec otherwise it overdubs and it records the same stuff over the first part of the loop which e da up in phasing etc…
Thanks for the answer.
This is the way I do it now too, but I couldn’t imagine that there isn’t an other way.
After the first 3 days I’m a bit surprised about this unit.
I’m an experienced musician, the operation of the unit is no problem since it’s not a ‚deep’ device… and I knew before about the tape workflow.
I like the sound of the synths and playing around with the ‚eurorackish‘ sequencers…
But there is so many basic stuff missing… very frustrating instead of having fun.
au contraire…the op1 is a very deep device that lends itself to great creativity.
but, it’s going to take more than three days to discover that, so we’ll let you off easy this time…
it’s easy to to stop overdubbing on tape loops with sequencers:
1/ in endless sequencer, add blank steps at the end of your sequence.
2/ in finger sequencer, make a second sequence with no notes playing. set sequence to replace mode (shift orange ). when first sequence is running, press on the second sequence, it will start at the end of the first sequence.
No… you are literally asking for the workflow to be changed. The fact OP1 has no undo and you need to actually think about what you are doing before committing to tape is a feature. It makes you more creative and less lazy
First: If you are all happy with this, you are right.
It just doesn’t work for me and I think we have substantial different concepts of being creative,
or what’s a ‘deep machine’ etc… that’s 100% fine.
I just have not the right mindset.
For me its just hard to get that a missing feature like undo should shrink my creativity because I have to overthink what I’m doing… but as I said its fine, if the company sells this at this price tag it seems that’s a lot of people exactly looking for a device like that.
Im going to return it to the dealer and be thankful for this experience…
squiddly: that’s not what I mean, if you’re listening more ore less carefully with every loop it adds the tape noise on top…
Blockquote it’s easy to to stop overdubbing on tape loops with sequencers:
Is there some reason they couldn’t add undo (maybe there is a technical reason)? This is a pretty common criticism of the OP-1. If they added it would you be upset? It’s not like you would be forced to use it. I would love undo if it is possible for them to add.
I think more than an undo feature it would be better to have more tracks so you don’t have to stack them all on 4. It’s stereo tracks and they could allow you to have 2 mono tracks for every stereo. Then you wouldn’t need an undo button.
or just turn loop off when you record your track, record through and just chop off the recording at the end point. your start/end points are remembered even when temporarily disabling loop. for me its a non-issue. i do agree though that an undo would be handy
Terminating overdub after one loop is a perfectly reasonable feature to ask. TE could bind it to shift + out when setting loop end marker. Make the terminal marker look slightly different when this is enabled. Would be pretty useful.
