Drum Pattern Question
Sorry if this has been covered elsewhere. I’ve been playing around with the pattern sequencer for making my own beats, one thing I can’t seem to figure is whether I can set individual volumes for certain elements, say like turning the volume of high hats down a few notches to make them less pronounced. Is that doable?
In the Drum sampler, you can adjust levels per key with the orange encoder. You can’t do it per step however.
Thanks for clearing that up.
@hiabex a good tip is ,while grid plays, press shift and a drum key (say hi hat) and the screen focus will lock to that drum allowing “tweak as you listen” control.
