Drum synth kits
Don’t have op with me to investigate and can’t find the info in manual. Wondering how you make a kit using the drumsynth? Specifically how do you allocate/p-lock different synth settings per key? Is this how it’s done or do you need to record individual drum synth hits to tape then resample as a 12 second sample in drum sampler and set start points? like when you use user drum samples etc?
It’s per key. No need to sample.
Cool, thanks. I’ll figure it out when I get home.
@Zzzach also, it’s not possible to play an individual drum sound from a kit chromatically via keyboard without resampling in to synth sampler right?
Just getting my head straight before making some drum/noise sets etc in DAW to import :wink:
That’s right. Each key is its own sound.
@Zzzach also, it's not possible to play an individual drum sound from a kit chromatically via keyboard without resampling in to synth sampler right?
You can use the Endless sequencer for that: Enter the sound you want to pitch and possibly hold it for a couple of steps (16 or so usually does it for me). The sequencer will automatically pitch your sound when starting it off different keys on the keyboard. Try tuning your initial sound to a C to minimize transposition headaches.
