Just bought Op-1 a couple of weeks ago and have been studying the machine almost every day. But here’s a problem I have not solved yet on my own. How to enter long notes on pattern sequencer? Apart from drum samples, the sounds - vocals, keys etc. - seem to fade away quickly when entered into pattern sequencer. Is there a way to make them longer?
You can using the endless sequencer by holding your note and shift and then use the right arrow to extend the note across steps.
If using sampler you can set notes to “play till the end” with orange encoder.
This may help with voc samples in pattern seq.
Problem solved. Thank you so much for tips.
