Apologies if this is something you hear all the time.
I just got my second hand OP1. It was working fine for a few minutes but then it crashed. I tried turning it back on but nothing happened ( not even the faint click I have read about). When I plug it into power none of the charging lights come on, also when it’s connected to power a constant static buzz comes out of the speaker.
Could you guys help me diagnose the issue? or recommend someone in Australia ( preferably Melbourne) who could do some repairs for me?
Also when the battery is drained, the charging animation does not appear instantly. Just let it charge for a couple of hours. Be sure to use a dedicated USB charger, a computer USB port doesn’t work sometimes.
thanks for the tips guys. I had it on the charge for at least 5 hours whilst trying different cables with nothing to show for it, ( including no charge lights). I’m gonna try resetting the battery and see how I go.
It’s leave the power on for a day even if nothing is happening, then putting it on for a long charge. I was informed by the previous owner that this happened and worked before after he it had been sitting there without use for a few months
update! left it on to charge overnight, still not turning on and no charging lights… but! the loud buzzing did stop! small victories? will leave it a bit longer and then try the charging with the power on.
However, that static buzz puzzles me… sounds like a problem with the charger and/or the cable. Did you try an other one, or maybe the USB port of your work computer?
Have tried all different combinations of cables etc. Still no luck yet. The buzz leads me to believe that something is inherently wrong with it. I might just have to send it somewhere for repairs. Still waiting to hear from TE on where I could send it.
