Help with OP-1 not showing up as drive
I’m hoping someone here can offer some advice. Suddenly my OP-1 doesn’t communicate over USB.
-The USB cable is tested and working (same one I’ve always used)
-Tried connecting to multiple MacBooks (new and old)
-USB connector solder joints look fine on the PCB
-Device receives power via USB and charges
What should I try next? I’ve formatted the drive but it’s still the same problem. I’m thinking this is a hardware issue.
Does anyone know a bit more about the hardware on the OP-1? maybe there are some components on the connector board I can check?
Thanks
Had the same “thought” a few minutes ago as I formatted the device.
Just unplug and power on without cable plugged and after a few seconds it should say something like “no OS, connect USB”.
Turn it off, hit “COM” and power it on again, - worked for me.
I turn it on and it says ‘Missing content folder, Please reinstall OS’
I can put it in boot mode by holding COM whilst turning on. Then I can select option 1 ‘Upload firmware’. This should show up as a drive via USB. It doesn’t.
My (WINDOWS-)laptop said “no drivers found” while connecting it after formatting the 1st time, but after the second try it worked. So it shouldn’t be that big of a problem.
Ok thanks but it’s different in my case. I was hoping someone on here could maybe help me diagnose the hardware.
I’ve had this op-1 for over 10 years. It’s always shown up as a drive with USB until recently.
