New user of the OP-1. I just wanted to know how to connect my OP-1 to my Apollo Twin and put that into Logic 10.5.
Not super familiar with the Apollo, but I’d assume it’s like any other interface where once you have it connected to your computer, go into your preferences in Logic and go to Audio, then select your input as the Apollo. You can set it as the output to the Apollo as well if you plan to run speakers or headphones from the audio out. Then you just need an 1/8th to 1/4th cable adaptor to run the audio out from the OP-1 (top white output on the right side) to plug into the interface.
