How is it done?
Use the Ear as your input to the track you want to resample to (change input in tape mode by pressing shift+microphone). Then press play and record.
I suggest the technique I described in this thread:
http://operator-1.com/index.php?p=/discussion/380/preserving-levels-when-bouncing-to-ear
It depends on your workflow preference, but I find it simpler than changing the sampling input.
Alright, thanks!
if less than 12 seconds, you can record into the drum sampler
u can also lift+drop your audio from the tape straight into either sampler. shift+lift does all 4 tracks at once i think?
prob the fastest way if u work in smaller chunks
