;-)It's actually in the manual. You set up the freeze delay on each track a certain way. Then there is a play mode that pads 1-8 choose the note division and 9-16 chose the track it affects.Could somebody point me to the best video describing how to set up that stutter / beat repeat / freeze delay thing that dataline often does in his videos? From the looks of things, that's also a scene based trick is it?
Ah nice one @Virtual_Flannel, will defo experiment later
You have to set a delay on your track (can be the master.
In delay setting menu (double tap), set LOCK to 1 and maybe TAPE to 0, depending of the style of stutter you want.
In the regular delay menu set SEND to e.g. 1 and FB to 127.
Then you can either set the crossfader to get the SEND value to 0 when you want the repeat, or more conveniently use the DELAY CTRL mode (Fn + 5 down)
To play with the DELAY CTRL mode you have to be in play mode, not in grid mode = led of the rec button unlit.
You can now press your track button on the 8 right tracks to freeze the repeat and while holding it, press one of the 8 left button to set the length of the repeat.
You beauty, @LyingDalai - cheers for the detailed instructions. Looking forward to giving it a go!
Thanks @Virtual_Flannel and @LyingDalai for your tips, got that delay control mode working last night.
An even better track. Pretty happy with how this came out:
nice textures! I love Impact Gardening, it has some really great melodic bits that come in and out.
Fuck, the octatrack sounds complicated.
I really want one
The times I’ve used my OP-1 with my Octatrack, I just ended up thinking “I can do most of this ON the OP-1” ten times faster!
Ha! it’s funny how little my OP-1 is used now that Elektrons have entered my life. Although I think the OP-1 was crowded out more by the Monomachine than anything else. Although when we had a sudden power outage yesterday, I could at least sit outside and keep jamming on the OP-1 while the Octatrack and other synths were dark.
Some stuff I won’t use the Octatrack for, just because I want it to have a certain feel that the sequencer in the OT can’t give me.
