I love the last update 1.0.10.
Since my enthusiasm in using it, i was creating a track where there are about 5/6 instruments playing all together.
And that’s when i notice voice stealing even if the little chip icon shows up, but it’s not red.
Did anyone experience the same problem ?
Sure, it’s only got 24 voices so it’s easy to use those up with a few tracks if you’re not careful.
OP-XY can often run into this issue especially if you use sounds with long release in envelope and you don’t config voice allocation. If you manually set voice allocation in project settings at least on tracks where you expect such polyphonic sounds with long release you can improve the situation significantly.
Nice! thanks for the suggestion @rudolphrapid !
will check that out!
