Not sure if it is the general hardware limitation or unique to mine - I got my OP-1 a little over a week ago and found the frame rate starts slowing down to below 30fps (estimate) when:
It’s expected if there’s a lot going on. IMHO it’s a good thing though: It means the audio processing is running at a higher priority than the UI.
Ah, as long as the audio processing isn’t affected then it’s not a problem
I experience the same issue having several tracks on tape and using DSYNTH real time. Or sometimes in cases when G is set as the modulation source. The tape gets sluggish as the FPS is dropped significantly.
@eesn
I know what you mean. However the OP-1 is designed to look beautiful, but what it’s supposed to do is create sound. I think it’s cool that they gave more power to sound synthesis etc than graphics. It’s a limited processor so they need to make compromises. I’d rather have good sound and shit GFX than the other way round. As a software developer I approve.
