When I go to save a drum sample to the tape, the first six seconds of the pasted sample is all intense static, then the sample emerges. Does anyone know a fix for this?
More info about this: It’s exactly 5 seconds of static, then 12 seconds of drum sample.
@Kushy that is the code that is used to transfer presets of drum sounds - similar to the way TC units work. No real way to get rid of it other than using a tempo that gives you the right bar lines (maths!) and chop it out, or record it into a DAW, chop it out, then record back into OP
