Hi everyone,
First thing to try is make sure you have the latest OS firmware installed. There is a file and instructions on the TE website.
You should also do a factory reset after installing the new OS just to be sure everything is in a consistent state.
I looked at the TE website and it seems that the latest OS update included the sketch sequencer, is that right? This is already on my OP-1. I’ll try a factory reset tonight. Would you also download the latest firmware and try and install it just to make sure?
I think there were two with sketch?
Yeah exactly it does double hits. You mean it settled when you upgraded the firmware?
I think it’s a bounce in the physical keys. It just went away over time for me. I just stopped noticing it happen because it had slipped quietly away. Like I said, it’s worse when you’re playing on a soft surface… Like a fluffy pillow
Alright thanks, I’ll keep that in mind. I will try installing the latest firmware tonight and factory resetting.
Thanks for your quick replies.
You should be able to see the firmware version on start-up.
perhaps you have an active random lfo in the drum section – sounds like…
yea could be something like that. i know sometimes I have the sequencer on and i'm like WTF IS GOING ON!...oh right!
Oh, didn’t think about that, I’ll make sure to check out if that is the case. Thanks!
Or looping set up in the drum sampler? Or loop points in a synth sampler?
I have tried factory resetting the OP-1 now and I have checked that it has the latest update.
