left channel out and speaker not working
Sorry if this has been asked before, I couldn’t find anything quite like it.
My op-1 has been working fine until today. Just now, after I went into Disk mode for a while, then disconnected the op-1 from my macbook, and right after that it seems to have broken. The internal speaker no longer works when I have headphones disconnected, and when I plug in headphones, I only get audio out on the right channel. There is nothing wrong with the headphones, I’ve tried them with other devices. I’ve doubled checked I’m not in PO Sync mode. I even attempted a factory reset, and still no luck. I’ve tried turning the op-1 off and on (with waits in between) several times and it hasn’t made a difference.
If anyone has any suggestions, they would be much appreciated, thanks!
It may be a mechanical failure or bad solder joint in the output connector. This is a common issue with the OP-1.
