Hi,
There is a bug that stops you being able to lift from tape and drop into drum sampler. It is triggered if you lift and drop sample settings between keys in the drum sampler… after that, dropping audio into the drum sampler won’t work till you restart the op-1.
A fix for this is my number one wish for an os update.
Can you give a little more detail/explanation about what you mean when you say “between keys”?
Wow, didn’t notice that this thread is so old.
I am a new user of the OP-1 with the latest firmware. I have noticed that when I lift from tape and drop to drum sampler it works the FIRST time. But after that, I have to restart the OP-1 to get it to work.
Steps I use:
Tape mode: cut either end of a stretch of tape. Lift.
Switch to Drum mode: click Drop.
Always works first time, just don’t know what happens (or what I’m doing wrong) on subsequent tries to drop a lifted tape sample to the Drum sequencer.
