Longer sample on drumkit
Hello again.
Sorry but this thing is making me crazy.
I resampled a loop from a drumkit (it’s a stereo sample lasting 5 secs tops).
I created a new drumkit track, then i loaded the sample on the first note (C).
I can play the sample on the keyboard. but if i try to put it in the sequence, for example from the first step, nothing plays.
I tried to check envelop and other things. but it won’t play. does anybody know what’s wrong ?
Hey,
Have you tried turning the white knob to change how the sample plays?
You can choose between these playback modes:
  • Key – the sample plays only while you hold the button.
  • One shot – the sample plays all the way through from start to finish.
  • Mute group – the sample stops when another one starts playing.
  • Loop – the sample repeats automatically when it reaches the end.
You can also choose which sample you want to use from the keyboard.
When adding it to the sequencer, hold down “step 1”, and while holding it, press “step 16” , that sets how long the sample will play. ( if you choose “Key” mode )
Yes, checked everything
then created a new project, and loaded the loops i sampled previously, and it worked.
I will retry the procedure, seems that i can’t load samples created sampling from the machine directly in the project i am working on.
idk if it’s a problem with my machine or what.. will retry later and post the result.
Thank you!
Hmm, that’s strange. Could you confirm if you’re running version 1.1.0?
I’ve tested the same procedure here, and it’s working as expected.
Keep us informed if you notice any further issues or details.
