Hi,
I’ve read somewhere that’s possible to add or remove steps at the end of an endless seq already recorded. But can’t find the tips anywhere…
Was I dreaming ?
Cheers!
Once you have an endless sequence, you can do shift-left to reduce a step. You don’t see it reducing until you let go of shift, I think… so, say you have a 64 step sequence, if you hold down shift and tap left 4 times, then when you let go of shift, you’ll see it’s now a 60 step sequence.
I don’t think you can do it the other way though (make the sequence longer).
Hi,
you can read it here:
7.4 endless sequencer functionality
on the right side.
But I think appending new notes is not possible.
Thanks for detail, I’ve read this part but it never says that it can work after the seq is recorded
