Need help moving forward with Videolab on macOS Catalina
Hmm, the Videolab repo is pretty much dead/dormant for the time being. Can anyone help me get Videolab going on my system? I’m a developer, but not used to Unity. I’ve downloaded the latest Unity and tried several times with several versions of Videolab. Eventually I was able to sort-of solve my main issue (couldn’t use the imported assets) by dropping the videolab files into the Scenes subfolder of assets, but then I couldn’t use the Midi In/Out nodes in the patcher, they threw errors in Unity…all I want to do is just get started with development by following through the tutorial. Basically blocked at step 1… :confused:
Here are the issues in Videolab…
Cheers!
Not sure if you’ve tried this yet, but made a really simple Videopak template in Unity with instructions and download here: https://www.synthpaks.com/products/gif-looper-template-project-beta - It has videolab already installed. You need a specific version of unity though… it’s listed in the instructions. It’s a good way to mess around with a working project and see how I linked everything together…
Ah thanks, I’m aware of your project but I suppose I was thinking that I would go through the tutorial and then go to this and possibly other projects later…but this looks like it would be a good way forward now so I will try it this evening. Looks like you’ve done some really nice work here, much appreciated!!
Once you get the hang of it, the possibilities are endless! I’m just scratching the surface with the little bit I can comprehend… I’m not a dev… just a lowly graphic designer. ha
I just got this to work today. What worked for me was to make sure I was using unity 2018.4.x, per https://github.com/teenageengineering/videolab/wiki/Exporting-for-OP‐Z . I downloaded videolab from here: https://github.com/teenageengineering/videolab , built it and then exported the package. I think this is equivalent to having videolab-1.2, but this doesn’t seem to exist in the releases page for videolab. Then, I imported this package into VideoLabTest, and it worked.
I made sure to set the graphics api to gles2 for both projects. Some of the videopaks don’t work due to shader compilation errors. I think these were calls to gles3 that don’t exist in gles2.
