Is there anything already on the OP-1 or available online that gives off that warm, tropical vibe of nu-disco? Something in the vein of an Oliver Nelson or Kygo?
Try sampling some disco and funk with your drum sampler and chopping up the sounds. Then you can play or sequence the ‘chops’ kinda like a mpc.
So the op-1 has everything it needs to give you that sound you just gotta provide the samples.
Try sampling some disco and funk with your drum sampler and chopping up the sounds. Then you can play or sequence the 'chops' kinda like a mpc.So the op-1 has everything it needs to give you that sound you just gotta provide the samples.
Any tips, tricks, tutorials for this? I’m pretty new to this little guy
Yup sample some disco into the drum sampler. One tip is that the Drum sampler chops everything up evenly across 16 keys. So if you record a perfect loop it will be split into perfect divisions. Play with re arranging the chops and making something new. Throw down some four to the floor 909 kicks. Crank the master limiter. Experiment with Nitro on your samples for filter sweep goodness.
