http://now.teenageengineering.com/post/47348903156/op-1-drum-utility
https://www.xferrecords.com/freeware/
i've never even seen this VST version…? i'm on mac maybe standalone is mac only? i don't really know.
when u drop your files have u tried dropping them into the rectangle slots? not just the "Drop Files/Folder here" space..?
okay i found the mac VST within the standalone app. single files work for me when dropping in either spaces.
drum utility hosting within Live i think 32-bit. maybe your issue is w/ 32 vs 64 bit?
@Callofthevoid I see it easily
@callofthevoid
https://xferrecords.com/freeware/
Thanks for link. But looks like he only added 64bit for Mac. I’m on Windows
oh didn’t see that. sorry b
maybe email duda like the gentleman above did?
No worries, thanks anyway. Yeah I’ll drop him an email. Cheers
here are 2 tips for win 64x users trying to get the 32x vst to work. you can either:
1) use the demo of jbridge. https://jstuff.wordpress.com/jbridge/
20 minutes should be enough for getting some drum kits together
2) use this 32/64bit vst host http://www.hermannseib.com/vsthost.htm
download the vsthostx86.zip prog is pretty self explanatory even though its in german. and it lets you host 32bit vst plugs on your 64bit system easily.
however I still got the issue that I can’t drag’n’drop single files. I’m on win7. will try to reload the plugin and see if its helps.
Thanks for the tips. Still haven’t got round to going back and trying to get it to work. Will check it out again some point soon…
@jack_hightower did you ever find a fix for the single file drag ‘n’ drop? I’ve just started using the drum utility and am experiencing the same issue,…
The fix is essentially to hop over to op-1 fun and get your kits done there with the new interface. I still have the issues with the plug in and therefore I hardly use it.
