Hello everybody! My name is filippo and this is my first discussion here, nice to meet you all
I have an annoying problem regarding my OP-1’s TE-boot screen mode:
when I boot the OP-1 up on TE-boot mode, I press any number key and nothing happens, everything seems stuck/frozen.
when I use the same numbers in normal mode (synth, drums, tape, etc.) everything works fine.
I tried connecting the usb cable to my imac, nothing changed. I actually tried quite every thinkable option…
as you can understand, this makes every kind of test/upgrade/etc. impossible to perform.
I already emailed the TE support about that, and they obviously told me to send the OP-1 to them, so they check it up and eventually (hopefully) repair it.
before going on with that option, I thought that maybe somebody in here already had the same issue and/or maybe someone has some good and useful hint to help me out with that.
thanx everybody in advance!
Filippo
PS
I made a video which could help understanding the problem
