I haven’t used my OP-1 for months, and it can’t turn on now.
Below is the symptoms:
When i plug in the usb, the speaker beeps and LED 5 dots light up one by one (including the red one) then disappear.
Does this mean the battery is full?
Ive charge it for more than 48 hours but still can’t switch it on nor entering the TE Boot mode.
Sometimes when I witch the power button to “off”, I could hear the speakers beep once.
I happened turned it on once yesterday, but it turned off itself in 30 seconds, and remains off until now.
I’m planing to DIY fixing it, but not sure whether is it problem of Battery or the connector board.
Thanks for replies, i can turn on my op1 normally now.
Here’s how i fixed it:
Take out the connector board and use the electronic spray to clean up the switch button, and working it forth and back. Then it could switch on normally.
start into COM mode and update the firmware.
But I found out the center F key are not working (no response at all no matter how hard i press it)
I will try clean up the keybed with electric spray and keep it updated here.
