Could you share your equipment/technique to record beyond the album capacity? For example, if you’re doing a live 2 hour session, what do you record to?
If I understand the question right, you would probably use line out to a computer and record all of the output there. You can use any DAW/recording app you like. Audacity is free if all you need is to capture the audio. You would then have the computer output the audio to your speakers, or you could use a headphone splitter on op-1
Thanks, BE-Code. I was curious to hear about the actual equipment used to capture the audio. I personally use the minifuse2. At the time of my question, I was severly screwing up the connections to the minifuse2 thinking it was faulty. I had lost all hope and was wondering what others were using.
It’s all good now.
