Hi guys, the screen of my OP1 only works when it’s plugged into labtops or power source. Have any of you guys met this problem before or any one knows what wrong with it? Thank you very much!
sounds strange. maybe a battery issue? possibly the screen does not get enough power from the battery? how old is your unit?
Almost 2 years.
than the battery should be fine. what about the hardwaretest (com key on startup)
It’s fine now! I dropped it on the ground, and it’s working again. Thanks so much for your help
