Hi all,
I have my OP-Z plugged directly into the Bass Station II via a USB c (out of OP-Z) into the BSII (USB b). It works! I can sequence! Great!
However, every pattern change on the OP-Z changes (increments) the patch on the BSII. This is not great.
I’m attempting to use the OP-Z to sequence Afex mode on the BSII, and while it works mostly as it should, the pattern change / preset change is a real showstopper.
The OP-Z is sequencing out of the chord channel to the BSII. All other tracks on the OP-Z are set to a different MIDI channel.
Channel 1 to active track: off
MIDI In: off (which is weird because adjusting the pitch bend on the BSII fucks with the pitch of the OP-Z)
MIDI Out: Enable
Clock in: Disable
Clock Out: Enable
Alt. Program Change: Disable
MIDI Echo: Disable
I’m just floating this out there to see if anyone has had issues like this and how they may have gotten around them. If this has been answered elsewhere, just send me to the right place, please!
Thanks much.
