I tried to update the midi config by changing the midi.json in content mode, but when the op-z restarts, it just resets the midi.json file content to factory settings. Am I missing something? Changing via the app works fine.
And like it happens so often, the answer is staring me in the face minutes after posting the problemā¦
The issue was a comma in wrong place due to a copy/paste mistakeā¦ anyway, will keep this post up in case somebody runs into the same issue. Conclusion: If there is a syntax issue in your midi.json, the file will the rebuilt with factory settings upon start-up.
