Those are nice![]()
Playhead details on granular. After adding the freeze function I needed a way to make it visually clear that the audio was frozen without touching the design.
First I tried making the waveform orange, but it looked meh and ruined the look. This simple switch between blue (normal) and red (frozen) gives you all the information you need
Just for some inspiration, Here are some graphics from the movie “Wargames” with Matthew Broderick from 1983…
Definetly op-1 Style ![]()
I feel like there should be a cleverer way to use the Record feature. It’s great for mixing down finished tracks, but it would also be useful for bouncing tracks down and keeping them in stereo. The main problem is that playback and recording don’t sync properly with the tape. If this could be fixed, you could bounce four tracks down to the Record, then play them back onto two tape tracks.
Yes I added a kill count to my engine. It counts up to 100.000 before it resets. But of course, you can be nice and not do anything naughty. The birds will appreciate it.
Suggestion, I was wondering if there’s a way to adjust the MIDI CC’s routing and add some numbers to control the MASTER FX parameters? The only way I find to do it is using the encoder CC (Encoders: CC 102 to 105 turn blue to orange. Values 1 to 63 turn right, 65 to 127 turn left.) But id like to be able to continue playing in the OP-1 and having just my MASTER FX patrameters movings, not necessarily the page in on. It seems to exist on the OP-1 MODS firmware with these value:
Also, when I assign an LFO to a parameter with a push menu
for example: HAIL
I assign an LFO of the QUAD to the blue encoder of the FX = TIME
But If I want to assign to the PITCH (blue encoder pushed), im not able to assign it to this parameter.
I dont know exactly how it would be the best way to incorporate this feature of routing to second parameter (on SYNTH and FX).
On the C64ARP, would it be possible to add a random option in table?
The MIDI SEQ doesnt work, while doing the procedure: holding SEQ + TAPE, the midi sequencer doesnt appear.
thanks
Is anyone working on this SP202 or is it simply a wish at the moment?
Exactly, just a wish at the moment unfortunatelly, I tossed in as inspiration… can’t code by myself![]()
Ah, that’s a shame. Good idea.
Hey this looks cool. The graphics should absolutely stay this way. It has character
Also to anyone making graphics, @Instant_Fidelity made a nice kit from which you can pull all kinds of nice information: OP-1 Design Kit · SquareWave Studio
I personally only use essentials like color values from it, but it might help some of you get started.
At the end of the day, use your creativity and imagination. An agent does not understand human interaction and emotional response to what you see on a screen.
OP-1 is filled with different design choices, every stock engine has different graphics. Be like TE, make cool stuff and don’t worry about what someone else thinks.
It sounds so good btw! I am using the Reverb from hundekraft after Mutable Instruments Elements and waaweeiiiii!
