My OP1 keeps crashing for some reason… I was using the drum sequencer and it shut off mid record on the tape function. I tried a factory reset, and now it won’t turn on. If I plug it into the computer it will turn on, but then it seems to shut off again after a few mins.
What is the battery life at?
Have you been able to resolve the issue? I also had random shutdowns, in my case the power slider had a loose connection - I had to take off the connector board and just reseat the button. Works ok since then. Good luck!
