Is the MIO2 from Iconnectivity can sync an OP1 with other midi gears?
I am also very interested in this possibility even though it a bit expensive after butting a Kenton USB midi host to try and make midi controllers work. I am now looking into USBotg (on the go) connections as it might serve as a midi USB/USB host which seems to be what is needed for a lot of modern midi gear. Any experience with USBotg by any chance?
Looking closer at the MIO2?it seems as though it only has USB type b which means it won’t serve as a midi host which is what a lot of hardware needs. I believe it would work for the op-z but not the op-1. But these things are shadow games so you’ll never really know till you try.
