OPUS: a Mod Suite for the original OP-1 (246)
I quite like having scales and chord settings readily available, but don’t mind if the combo becomes help + press either
Something fun coming. Video here: Reddit
One request. Do you feel like taking a look at Palme? It works fine but clearly isn’t optimised for opus, the push knob turn functionality is a bit laggy. I think it’s a special fx and the only thing I use from other fw.
Looking forward to your plugins! :slight_smile:
Would love to but need to prioritize other things first. I can check next week.
Since @LizardMan said the bridge module is there just momentarily until people port their stuff. Then to me only make sense to tie that “help = fn” behaviour to the bridge module entirely.
Meaning, once the bridge module is deprecated, or disabled by user, we get the stock behaviour back.
OPUS 2 beta 3 is out
mostly fixes from your reports:
  • performance improvements
  • hundekraft 3’s gin and drum+ kits don’t stop the start anymore, they play as the stock drum kit and the op-1 tells you which engine they need
  • the op-1 now tells you when a plugin wasn’t installed and why, and files copied in disk mode get picked up even if it was switched off there
  • hundekraft’s effects and the bridged sequencers (peal and co.) don’t crash or freeze through the bridge anymore
  • tape undo loads fine with lots of plugins, and there’s no more limit on how many engines, effects and sequencers you can load
also new: a trigger guard plugin for keys that fire twice (adjustable), and outatime’s drive type is on shift + orange now.
update on the site: https://opus-op1.pages.dev
everything that changed: changelog · opus 2
until bridge becomes redundant, i’ll test a few different approaches and see which fits the ecosystem best: fn + bridge merged, fn in core + stock help plugin, stock help + fn as a functionality layer plugin.
already loving it
Sadly, it keeps going. I tried with the warble effect, instant crash, then with the oracle sequencers as well.
damn that’s not good news, sorry. i will investigate the issue further and maybe run a test on all their publicly available plugins.
Does a crash log get printed every time a crash happens? Would be good to have I think.
yeah i have that on my dev build already. I’ll release it soon.
Crash log plugin ftw
For those not in the discord, Sammibabe666 has ported their plugins to OPUS.
They have not been tested on hardware by the dev, but my personal experience with the bloodmoon one is very positive and smooth.
Praise the sun!
Cool concepts! But if the developer isn’t testing on hardware that’s a bit disconcerting.
Not to worry, the dev is on it and improvements will be made. So far Bloodmoon is working great.
Currently working on a very nice synth that has classic Roland sound. Think SH-101, System 100m. it has a massive sweet spot like the originals, 8 controls max and a legendary sound.
Will share a beta today for everyone to test.
As promised(well at least in my timezone)
is There a way to turn off the scale and chord push-button functionality?
if you do not want the scales and chords feature at all, remove its .opmod file from the device. there’s currently no way to operate the plugin only from its mod menu page, but i can add a “use knob press menu” toggle for you in the next update.
