Im having problems with the Photomatic app freezing. It gets unresponsive to buttons on OP-Z, and the pictures dont show up when choosing Roll in the app.
I have updated the firmware, did a factory reset, reinstalled the app, and it still freezes the same way. It does work for a while after a factory reset, but then it gets unresponsive again.
Does anyone know if there is anything I can do about, or if there are things I have overlooked?
And today it freezes all the time. It won’t let me play the pictures with the keyboard and the sequence doesn’t play. Whats going on?
Solved it. Accidentily i put the op-1 in midi sync to op-z while op-z was midi out to op-1, that messed the midi page in the op-z .
Now it is back to normal.
Yes! Thank you! Seems to be a midi issue for me also.
It works fine when I have midi in and clock in enabled, and clock out and midi out disabeled.
If I enable midi out and clock out it freezes again.
It dosen matter if it is connected to outside midi or just used standalone on battery.
Maybe its a bug?
