Hi all
Another PO33 issue! Maybe mines cursed.
When adjusting the trim level. After releasing the dial, the number will continue to change on its own for a few digits. It makes it hard to get an exact trim. I assume this isn’t normal?
Hi all
It’s normal. A bit annoying at first, but you get used to it.
pretty much every PO i’ve ever owned gets this at some point and to varying degrees
its especially annoying on the PO33 tho.
if u swap the pots for better quality ones this goes away completely
