Does anyone knows what this comnbination of keys does?
I see a yellow light in one of the 16 tracks when I press and hold rec and I can select other but don’t know what it is for. I couldn’t find anything in the manual.
Thank you
https://teenage.engineering/guides/op-z/general-operation#recording
Basically, you’re putting the OP-Z in step record mode when you hold (rec). When you press 1-16 you’re selecting which step to input a note in. Once you press a note key it will record it to that step and move to the next one.
Thank you!! n00b here as you might guess
