Record mode ARM/LOCK does not record CC parameter changes
If using the record lock function or the record arm mode, the OP-Z does not record parameter changes.
OP-Z records parameter changes only while holding down the record button.
I‘m note sure whether its a bug or not. Performing a recording with e.g. pitch bend or filter sweeps is almost impossible if you have to hold down the record button.
What is your opinion about this issue?
I think it’s intended to do so but personally I would love to see an option in the general.json file to enable “record all movement” when rec is activated!
